any v12 swaps?
This topic is closed.
  • E30SPDFRK
    • 5690
    #31
    Originally posted by e30s52
    or an n62 swap.
    whoa whoa whoa, what happened to "best for the money"? ;)
    Byron
    Leichtbau
    • e30s52
      • Oct 2007
      • 5235
      #32
      N62 is a good motor for the most part. Just dont give it to much boost and your golden.
      www.gutenparts.com
      • TDE30
        • 7042
        #33
        Boost isn't the question, cost is.
        RickSloan, good point, although I'd just as easily opt for the M106. K27, forged internals, Motronic, 8.0:1 CR, etc. etc.
        - Trey
        E90 325i/6 (ZSP, ZPP, ZCW)
        E36 325i sedan
        E30 325i sedan
        Volvo 945T
        • e30s52
          • Oct 2007
          • 5235
          #34
          I have seen a few go for around the same price as an s38.
          www.gutenparts.com
          • TDE30
            • 7042
            #35
            It's an odd swap though. A brand new, super smooth V8 would be a wiring nightmare in an E30. An S38, not so much.
            - Trey
            E36 325i sedan
            E30 325i sedan
            Volvo 945T
            • euroshark
              • Apr 2006
              • 3491
              #36
              The regular old US spec B34 has the same forged pieces as the M106 and 8:1 compression ratio. The only big difference with the M102 or M106 is the oil squirters for the pistons.
              A turbo M30 really is hard to beat. You get a nice fat power curve and a freaking mountain of torque even at low boost levels... And you don't even need to think about touching the block until you start getting really crazy with the boost.
              • TDE30
                • 7042
                #37
                Ah, I didn't know that the B34 had the same forged pieces as the M102/6. I think the only difference aside from the oil squirters in the pistons are the sodium (or Nimonic as I have heard before) filled valves which supposedly dissipate heat better (from what I understand.)
                - Trey
                E36 325i sedan
                E30 325i sedan
                Volvo 945T
                • E30SPDFRK
                  • 5690
                  #38
                  I believe they have knock sensors too.
                  Byron
                  Leichtbau
                  • RickSloan
                    • 2401
                    #39
                    this is true, but the stock b34 seems like the best to me still because of the fact you can put out loads of power without ever really "needing" to open the bottom end.
                    Need Illustration or Design work? www.robbiebyerly.com
                    • TDE30
                      • 7042
                      #40
                      Quite true.
                      - Trey
                      E36 325i sedan
                      E30 325i sedan
                      Volvo 945T
                      • dps1
                        Sitting in timeout
                        • Jan 2009
                        • 90
                        #41
                        how much do you think the swap itself will cost? no including motor or tranny
                        • e30s52
                          • Oct 2007
                          • 5235
                          #42
                          Well if you cant afford to pay Jandersen 50 bucks then you cant afford the swap.
                          www.gutenparts.com
                          • RickSloan
                            • 2401
                            #43
                            so to clarify...
                            more then $50 bucks...
                            • SpecM
                              • Oct 2005
                              • 4531
                              #44
                              so to clarify...
                              correct
                              and you own me an e12 ;)
                              1989 cirrisblau-metallic 325i
                              • RickSloan
                                • 2401
                                #45
                                Originally posted by SpecM
                                correct
                                hahahaha
                                very true, i'll have to make it up to you some how! Actually you ask Ldsbeaker to make it up to you ;)
                                she has a clutch and e30 sport seats now, soon to have a 5 speed, and a buddy is going to fix the frame rail!
