Please help with my Turbo M30!! :)
  • HandalE30
    • May 2008
    • 109
    Hi people, I´m just about to turbo my M30 powered E30 and was wondering how much boost will the engine safely take with stock internals without damaging the engine at all? I already have the /AEM UEGO (wideband sensor) / apexi AVC-R boost controller / apexi afc neo(engine managment) with the variable TPS / intercooler and a vdo oil presure gauge to run the turbo safely but dont know the max boost. And if someone has tips on how to make my turbo exhaust manifold or which aftermarket manifold would fit the M30 in a E30 chasis with a top mount without having to modify the engine bay or hood I would really appreciate it. Thanks alot !!! =) oh and I also dont know what size of exhaust to use, I wanted to use 2 individual tubes all the way but dont know which size to go with! Gracias!
    [/URL]
  • RickSloan
    • 2401
    b34 or b35?
    i think TCD runs 16 or 18 lbs non-intercooled with no problems. So if your intercooling you should be great in that range and have tons of power.
    Look at good and tights threads, he just finished his.
    Good luck!
    Need Illustration or Design work? www.robbiebyerly.com
    • HandalE30
      • May 2008
      • 109
      Its a b35 from a ´91 E34 automatic. 16 or 18 lbs!!!!!! wont my engine break down with stock internals :( I have seen their original setting but non go so hi, maby people boost it more after using their kit. ive seen his threads but his engine is a b34 and think it has a different compression. but ill check again! Thanks alot
      • kronus
        • Apr 2008
        • 13032
        Originally posted by HandalE30
        Its a b35 from a ´91 E34 automatic. 16 or 18!!!!!! wont my engine break down with stock internals :( I have seen their original setting but non go so hi, maby people boost it more after using their kit. But Thanks ill check on good and tights threads!
        Nope, M30 stock internals are a beast.
        Good n' Tight ran a stock B34 up to 20 psi and got north of 400 HP reliably, if I remember correctly.
        cars beep boop
        • Lurker27
          • 821
          I'd be careful without the ARP head studs much over 10psi though.
          '89 335is +turbo
          • BoostMW
            • Nov 2007
            • 183
            10 psi non intercooled. 18-20 intercooled with good tune,HG,and studs
            • RickSloan
              • 2401
              i think this is your best simple answer right here
              • deutschman
                • May 2008
                • 5958
                i dont know about that body kit...
                • Miasma
                  • Apr 2007
                  • 2009
                  He didn't ask about that. He asked about turbocharging the M30 he has under the hood.
                  • Good & Tight
                    • Apr 2004
                    • 2057
                    Actually it was 14psi not 20, I am running 18psi now with headstuds and a stock headgasket.
                    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                    ____________________________
                    E-mail Panayiotisx2@gmail.com
                    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                    • LowR3V'in
                      • 4209
                      But then you have super low compression with the b35 head
                      on the b34 block, don't you?
                      • Good & Tight
                        • Apr 2004
                        • 2057
                        It's a B34 head.
                        • Spinning Tires
                          • Feb 2007
                          • 283
                          what kind of gas do you run at 14 and at 18 and do you have a stand alone to retard the timing?
                          First: 1984 318i
                          Second: 1987 325
                          Third: 1987 325is
                          Current: 1990 325i (Soon To Be 335i)
                          • HandalE30
                            • May 2008
                            • 109
                            Ok so without the head gasteket you ran 14psi but the b34 has an 8:1 cr right and my b35 has a 9:1 so I think ill run max 10 psi like they say till I change the studs and gasket. You got 370hp out of your b34 with 14 psi (wow :o) , how much power do you think I can expect from the B35 with 10 psi intercooled and my apexi managment? o and if i go with a twin exhaust would it be enough 2.5" each? Thanks guys!
                            • HandalE30
                              • May 2008
                              • 109
                              I think at 14psi he ran 93oct. its in one of good & tight´s threads!
