help with my motor swap
  • McFLY425
    • 3
    for the last few weeks i have been going back and forth between M50 and M30 for my 91 318i. i have read til my eyes hurt. so which is the better swap? (for weekend driven) please help
  • yert315
    • 2734
    honestly, I would go with m30. reasons:
    -cheaper swap - for the most part
    -more power
    -motors are near bullet proof
    -torque
    And you posted this in an M30 forum, where you will get a lot of praise for m30's
    • E30SPDFRK
      • 5711
      This has been covered multiple times, but I'm bored so I'll compare the two.
      M30 +'s
      -cheap
      -plentiful
      -bulletproof
      -torque
      -simple
      M30 -'s
      -hard to find 5spds
      -simple
      -more custom work to the swap
      -bad mileage
      M50 +'s
      -cheap
      -plentiful
      -good on gas
      -simple to swap
      -vanos
      M50 -'s
      -usually beat on
      -less power than m30's
      -vanos
      Both are great engines that can be put into an e30 for cheap. It really just comes down to which one you prefer.
      Byron
      Leichtbau
      • RickSloan
        • 2401
        i was in your same place a year ago...
        there is an m30 in my car now and i love it.
        the best way i can describe the experience while driving it is raw
        Need Illustration or Design work? www.robbiebyerly.com
        • Lurker27
          • 821
          Id say the m30 is better for weekends - more torque on tap to break things loose.
          '89 335is +turbo
          • pegase747
            • Jul 2006
            • 279
            Go for M30,
            I would go with the M30, for a similar price you will have a powerfull stock reliable engine ( 211hp stock ) and loads of torque, with a lot more power if you tune it ( turbo... ).
            the plastic M50 :p needs to be revved hard to get some HP, so unless you want a track car with a light, hi-rev engine, then I would go for the Big 12v six, ideal for cruising !
            Cheers / Pierre
            1988 E30 ALPINA B3 2.7 #224/257 Made in Buchloe
            see more : http://www.r3vlimited.com/board/showthread.php?t=71686&referrerid=12460
            • euroshark
              • Apr 2006
              • 3491
              I agree 100% with everything that has already been said. The M30 is a pretty simple swap and in a light E30 chassis it's a blast. Tons of torque from super low RPM and they can still scream at high rpm, especially with a cam and headers.
              • E30SPDFRK
                • 5711
                m50 doesn't even have a weight advantage, its only like 15 pounds lighter.
                Byron
                Leichtbau
                • RickSloan
                  • 2401
                  m30 ftmfw
                  and if you want to go FI there is no contest
                  • McFLY425
                    • 3
                    thanks for your advice. the hunt begins
                    • pegase747
                      • Jul 2006
                      • 279
                      he he, what did you expect on the M30 swap room ???
                      Bet you will enjoy it a lot !
                      Pierre
