m30 and power steering.
  • LowR3V'in
    • 4209
    Hello. I was wondering what you d00ds
    do for power steering? Use the m20 or m30 power lines with
    the m30 pump? I don't think I've once read about this.
    Thanks. All opinions are welcomed.
  • Doughnut
    • Oct 2007
    • 869
    You can use the original lines, they fit right up for me.
    ///Monstrosity. (OO≡≡[][]≡≡OO)
    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
    • wildstoats
      • Sep 2007
      • 896
      By original do you mean from the E30 or the E28? I'm assuming E30 since the E28 uses the crazy hydro pressure accumulator setup. Also since the subject was brought up, has anyone used AN fittings for their power steering lines after an M30 swap? I was thinking about running some but I don't know if they will clear the oil pan since they stick out a little farther than the banjo fittings.
      • e30_kid89
        • Apr 2006
        • 489
        With a b34 PS pump (don't know if b35 is different), I used teh stock m20 lines with very very very little massaging to the high pressure line to line it up.
        • BoostMW
          • Nov 2007
          • 183
          I used b35 non self leveling pump from e34 and original lines
          • wildstoats
            • Sep 2007
            • 896
            Yeah, my e30 didn't come with any P/S lines, doh. How hard would it be to get the P/S lines on the rack after the engine is in? I was planning on dropping the engine in this weekend but if it's going to be a pain to get the lines on I may hold off. Unless someone in Ohio / Michigan has some P/S lines they want to sell me on the cheap :razz:
            • yert315
              • 2734
              ^^ have fun with that. I hate power steering fluid when it gets all over the place.
              BTW, are the b34/b35 power steering pumps different? I picked up a PS pump from an e28 and cannot figure out how it mounts to the b35 I got from an e32.
              • wildstoats
                • Sep 2007
                • 896
                I know the brackets for the P/S pump are different between the B34 / B35 but I'm not sure if the pumps have different measurements that would keep them from being interchangeable.
                • yert315
                  • 2734
                  that's what I needed to know. I have had the damnedest time trying to mount it.
                  • E30SPDFRK
                    • 5707
                    I'm using e30 pump and lines. I had to rig up some sketchy bracket from other tensioners to make it fit.
                    I think that the b35 setup would be best/easiest to use.
                    Byron
                    Leichtbau
                    • LowR3V'in
                      • 4209
                      Ok, I'm using the b35 pump with stock m20 lines.
                      Works well.
                      • Doughnut
                        • Oct 2007
                        • 869
                        m30, m40, m42, m20 and m10 (the ones I know for sure) all use the same power steering pumps, the difference is the brackets that mount them and the pullys.
                        • Jean
                          • 18228
                          Good to know, so they can easily be swapped over re-used if needed? Brackets/pulley comes off w/o any hidden issues?
                          • wildstoats
                            • Sep 2007
                            • 896
                            The bracket was pretty straight forward on my b34. 4 bolts, really obvious. It will all make sense once you look at it.
                            • Doughnut
                              • Oct 2007
                              • 869
                              The pulley has three 13mm bolts holding it on and the brackets are all fairly self explanatory when you go to mount the pump to the engine. :)
