Does the M42 have a Brake Booster Check Valve?
  • AmosCake
    • Feb 2021
    • 218
    Part number for that piece, doesn't seem to be in realoem. I believe its a check valve/pressure valve?
  • av8drvr
    • 110
    If I recall you need to search the M20 part 34331156703. ​
    • av8drvr
      • 110
      Looks like Bimmerworld has it for $37. New part# 34331156579
      • AmosCake
        • Feb 2021
        • 218
        I may be dumb but they look nothing a like. IS that one piece non existent? So that part number you sent does the same thing?
        • av8drvr
          • 110
          Yes. I had to replace mine a few years back and that M20 part works just fine.
          • AmosCake
            • Feb 2021
            • 218
            What was the sign that made you replace it? Whenever I press my brakes, it makes like an airy sound as if blowing air out. Brakes just fine though
            • av8drvr
              • 110
              Mine had actually come apart. Oddly my brakes worked just fine, I was poking around the fuse box and noticed the original valve was split in half.
              • AmosCake
                • Feb 2021
                • 218
                I see, thanks for the insights. I appreciate it
