I have an issue with the fuel injection system in my M42.
A few times over the past two years, the car hasn't started up and will just crank and crank.
Too much fuel is being dumped into the cylinders on either start up or shut down, which washes away the oil on the walls and causes low compression. (putting a cap full of oil in each cylinder and letting it sit for 10min will make the car fire right up and run smoothly).
The fuel pressure regulator has maybe 10k on it as I replaced it late last Summer.
I'm thinking it's leaky injectors, but the problem seems to be VERY intermittent. It seems like the injection system is either dumping too much fuel on start up or the injectors are leaking a significant amount on shut down. But again, this is a VERY intermittent issue.
Some one on M42club thought it could be the ICV, but I'm not sure how that would cause this problem.
