Sounds some of the like the typical m42 leaks. Oil filter housing is common, as are leaks from both oil pans.
I'd pull both oil pans, inspect the oil pump nuts (they fall out, yikes!), reinstall as necessary and put new gaskets on as needed.
You can pull the oil pan without removing the front subframe...simply loosen the motor mounts and jack up on the transmission (make sure you don't block the removal of the oil pan) until you can wiggle the oil pan out over the subframe.
