1991 318is?
  • hangtym3
    • 2
    1991 318is?
    Hello all, I've been searching for a 318 for a while and I found one that is local. I haven't seen it yet, I am going tomorrow, but had a few questions. The engine has 250k miles on it, and there is a small leak, he thinks it is coming from the timing chain tensioner cover? How long do these engines normally last and is this leak a big problem? I would like to do an engine swap a little later down the road, but this will be my dd for a while. When i' go take a look at it, whats a good way to tell if the leak is actually coming from the timing chain? Thanks in advance!
  • 1mz
    • Jan 2009
    • 641
    too bad youre in cali! id sell you a complete m42 to replace that one with only 147k for $250 haha. If i dont sell it soon ill part it out, so if you need parts, lmk
    http://l0st0n3.mybrute.com
    http://l0st-0n3.mybrute.com
    Work in progress: 1991 318i m50 swap
    Feedback thread :up:
    I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
    • Quadrajet
      • Jul 2008
      • 1278
      If it was me, I'd bring a can of Brake Parts cleaner and spray down the area and dry it up with a rag. Then after you take the car for a test drive see if there's any new oil there.
      • 3bvert
        • 1032
        I looked at one, owner said same thing, leak was actually from the block that mounts the oil filter to the main block, thats an easy fix
        I did not buy it, as the same week, my now new to me vert came up for sale, same money
        • wolfgangstbd
          • 960
          250k is alot of miles if you plan to beat up on it but dont wanna replace an engine fuck it.
          • CCR Engineering
            • Jan 2009
            • 41
            I'm guessing my car has about that many mile and I track it regularly. Mine also had a leak coming from the filter block. The seals/gaskets to fix all that isn't expensive at all and doesn't take too long to fix either. Drive it and if it feels solid and smooth run with it.
            • wolfgangstbd
              • 960
              im happy to hear that. your givin me hope my engine will last long as possible with tracking haha
              • BTP325ic
                • Apr 2009
                • 700
                ditto for my DD drift e30 i am working on,
                • CCR Engineering
                  • Jan 2009
                  • 41
                  I've had to fix some coolant issues and a leaking oil filter block but nothing in the motor. I guess its been well maintained and now I just beat it like a rented mule and it just asks for more.
                  • blitz355
                    • Jul 2009
                    • 113
                    I have 263k on my m42 and its still running strong, i think it has some leaks too. haha
                    • 3bvert
                      • 1032
                      so did he ever buy it ?????
