M42 idle problem and intake gunk buildup
  • iamsam
    • Jun 2008
    • 176
    I suppose these two problems are unrelated.
    Anyway, after the last autocross meet, my car developed a funny idle. When i start the car cold, it idles super rough and low like it has some wicked cams, and then stalls out. After the car warms up, it idles fine, but a bit high at 1000 rpms, which i figure i can fix by just adjusting the idle.
    I did some forum searching, and it seems the cure-all is to clean the ICV. Now please forgive my ignorance, but where is the ICV valve, and to clean it do i just kill it with some brake cleaner?
    I already fixed two vacuum hose issues and no change in the idle problem.
    Second question of curiosity is as i was taking the intake boot apart to find vacuum leaks, i discovered a whole LOT of grime buildup on the inside of the boot and in the throttle body. Its like a dirt and oil mix, not goopy or wet, just dryish and caked. What in the world would be causing this?
    Thank you guys so much for your help.
    PS i also posted this on M42club.com
    -SAm
  • grantlacey11
    • Jan 2009
    • 680
    did you ever find the solution to your idle problem? i have the same issue going on!
    • iamsam
      • Jun 2008
      • 176
      no, never found the problem.... i gave been getting alot of help on M42club.com, this place sucks for M42 info.
      I am currently wrestling with an overheating problem where my temp gauge tends to go over the halfway point consistently, and i am planning on maybe fixing the idle problem with a new ICV and O2 sensor, but i don't know if that will fix it.
      • Blip Bavarian
        • 236
        have you guys replaced all of your vacuum lines? It is the most common issue with the m42. and you can simplify the mess of lines running under the intake mani.
        My LS1 swap thread:
        http://www.r3vlimited.com/board/showthread.php?t=160030
        • iamsam
          • Jun 2008
          • 176
          yep, i did the "mess under the intake" delete a while ago...
          • wolfgangstbd
            • 960
            i hit my icv once when my car was running rough and it started running fine haha. i heard they can get stuck because of the grime.
            • ClassicSkril
              • 49
              I have the same issue except I havent done the mess under the intake mod. I did however clean my icv which helped for a bit, but now it's back.
