a turbo m42 takes work to actually dump out power.
i know first hand what is better to drive in the m20bxx vs the m42 powered cars. and ayone who owns a m42 will tell you also, a 318is. that 4 banger isnt much off of a 325i. you also can set the cams to different timings, which you cant in a 325i.
take a 318is. its also the PERFECT candate for a swap of any engine. especially the ls1 ;-)
60mph in 2nd gear makes a big difference on an autoX course. Most aftermarket chips will allow the engine to rev to 7200-7500rpm which makes the engine even more flexible.
