just wondering how they work before getting em in, i have 4.6L injec's and will install the mark D, so ny opinions will help.. Thanks
Any1 with mustang injectors on the m42???
They work the same as stock injectors, but they are 4-pintle which improves fuel atomization. You wont feel any difference.
They are the yellow top injectors. 19lb/hr
Is your car running really lean? Does it need more fuel? If not, I would stick with 19# to avoid economy and driveability issues.
The 24# injectors from a ford taurus 24v will work just as well. The junkyard is your friend :D
The car will run with 24# injectors. Several people are using them but I prefer 22#. With stock injectors, my engine went lean past 4500rpm. With 22# its right around 12.7-13 afr at WOT.
592whp
