Clutch Problem
    Clutch Problem
    Hey guys! I need your help.
    SO, a couple of weeks ago I started hearing some weird semi high pitch sound coming from the engine bay. You could only hear it when you depress the clutch pedal.
    I was meaning to find out what it is and try fixing it..but got busy and was hoping its no big deal.
    SO, today it got even worse. When in neutral, a really high pitch noise comes on and off randomly but I can always shut it off by depressing the clutch maybe and inch - inch and a half (the little play that it has)
    ALSO, when in neutral and I depress the clutch all the way down I can feel and hear something working hard (maybe like a sort of grinding in the tranny). Through the pedal I feel as if something is grinding and the pedal is giving off vibrations.
    I don't understand the whole transmission much but I am a quick learner so ANY help will be greatly appreciated!:)
    http://vnmi.mybrute.com
    :razz: 1991 Alpineweis 318iS
    :arrow: 1991 Briliantrot 318i
    Its your TOB (throw out bearing) <---- Spelling?
    Mine did the same thing just before it went all the way. Change it now, it will save you some stress in the future.
    ** Lot's of M20 turbo parts for sale.**
    Turn key track car.
    http://www.r3vlimited.com/board/showthread.php?t=222066
      it sounds like the TOB. its a bearing on the input shaft of your tranny. cost abou $45~50. pain in the ass to replace but not that hard
