A few M42 problems.
  • pbr87
    • May 2008
    • 853
    A few M42 problems.
    1) Car has somewhat of a lopey idle when it's cold outside. Seems to happen only when the temperature is below 50f.
    2) Engine temp needle randomly went up over the halfway point today....and when I checked, the coolant level was below the cold mark when the engine was hot...but I've never had this problem before. Come to think of it, I think the coolant level was this low when I bought the car a few weeks ago. Also, my guage cluster is having problems...could the temp needle be related to this in any way?
    3) When I test-drove the car, the front left wheel made a rubbing noise whenever I turned left. Previous owner said it was a camber issue, and the car just needed a wheel alignment. Well....I had a wheel alignment done, and it still makes the rubbing noise.
    Originally posted by accident
    I have achieved the title of Douche of the month.
    Discuss.
    Originally posted by kronus
    It was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
    1990 300ZX TT 5spd ($6,000)
    1991 318i 4dr 5spd (DD)
  • BenM
    • 2184
    1) yes
    2) no
    3) headlight fluid
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • pbr87
      • May 2008
      • 853
      Originally posted by BenM
      1) yes
      2) no
      3) headlight fluid
      Discuss.
      • jrobie79
        • Mar 2006
        • 2525
        i believe there is a grounding screw on the back of the cluster that needs to be tightened to fix the temp needle from bouncing around
        1991 318i ---- 308K - retired
