So my #4 cylinder is dead... 50psi or so upon compression test. The car was idling for ~2.5 hours, started to run a little rough, I thought it might have been carbon build up on the plugs so I revved the engine up. It idled fine again for 5-10 min and then got pretty rough again. I pulled the plugs and #4 was full of gas (3-4 table spoons... like swimming in fuel).
I'm deciding whether or not to rebuild the bottom end, or just purchase another used block. Getting another used block would probably be the cheapest and easiest route, I would guess.
I've completely torn apart an M42 before aside from the bottom end. I'm familiar with the parts and such, but not super familiar with the process by which to rebuild it. Cylinders 1,2, and 3 are great, so I'd probably just replace the rings on #4, and rehone it if it looks scarred.
Any advice? What does it all entail? New crank bearings?
M44 crank time?
M44 crank time?
