Aluminum Radiator
  • longms
    • Jan 2007
    • 280
    Aluminum Radiator
    Where would one find an aluminum radiator that could be used with the M42 motor. I see ones for the E30 6-cylinders but nothing that is specifically for the M42. Will those work or are the radiators different between these engine models?
    '91 318is Alpine II- || HR Sport || Bilstein Sport || Poly RTAB || Treehouse FCAB || Poly Motor Mount || Poly Tranny Mount || Poly Diff mount || IE Sway Bar || BA HP Coils/Wires || 19# Injectors || SSR Comps w/10mm spacers || Hawk Pads || Fog Delete || Magnaflow Exhaust || Z4 3.0 SSK ||
  • longms
    • Jan 2007
    • 280
    Will the PWR radiator with p/n PWR5340 fit into a 318is???
    • scottinAZ
      • Dec 2009
      • 1312
      try this one
      I saved 15% on my Bimmer parts by switching to ...
      • longms
        • Jan 2007
        • 280
        that is nice but I am trying to eliminate that stupid plastic tank on the side of the radiator. I want an all aluminum radiator.
        • dj01540i6sp
          • Jan 2009
          • 349
          m42 Radiator / Aluminum ???
          check out zionsvilleautosport.com. I bought one for my 2001 540 and it is well built and fit like a glove.
          • longms
            • Jan 2007
            • 280
            will do...thanks for the input...this will get my hunt started...
            • Stu
              • 4083
              I think Mishimoto is developing one for E30 318is.
              • longms
                • Jan 2007
                • 280
                I hope they do. They seem to have quality stuff. Zionsville has some sick radiators for our cars but at almost $1,000 I would rather get a new-ish stock radiator instead. I also want to do the fan clutch delete and put an electric fan on the radiator. Should I wait to do this or is this the kind of thing that I could take off and mount on a new radiator?
                • 4bangerfury
                  • Aug 2009
                  • 335
                  I forget who, but I've read about someone using the mishimoto radiator for an e36 m3 in the 318. They used the overflow bottle from another e30 or e36 in conjunction with it.
                  • longms
                    • Jan 2007
                    • 280
                    Nice...did you see that on this forum?
                    • 4bangerfury
                      • Aug 2009
                      • 335
                      the rest of the thread was about finding the OP's coolant leak.
                      • longms
                        • Jan 2007
                        • 280
                        Was the rest of the thread about a coolant involving that radiator or an OEM m42 radiator? Thanks
                        • newman
                          • Mar 2007
                          • 1159
                          I had this one custom built for my car for 250 bucks at a local shop... Obviously a bit different than what you want, but it's something to consider. I'm willing to bet that the local shop would build and ship one to you...
                          Moxies Radiator Inc
                          (716) 824-5475
                          The owner's name is john. He's a little spacey but is a solid dude...
                          More info here:
                          1987 325is: 495whp/400ft-lb
                          UPDATED 03/12/10!: RB26DETT Swapped E30
                          • Haraise
                            • Oct 2009
                            • 64
                            Necroing this back, did anyone finish development of the all metal M42 radiator?
                            Failing that, where's the cheapest place to get a good replacement?
                            • rThor432
                              • Feb 2007
                              • 3907
                              Zionsville and eBay are the answers you are looking for.
