Oil on coil pack
  • TooTall90
    • 338
    Oil on coil pack
    so while i was replacing my thermostat a few days ago i started looking around my engine and out of curiosity decided to check the coil packs. i was pulling them out one by one and noticed that one of them had oil on it. the rest were completely dry.
    i've done some research online and it seems to be that the problem is almost always a bad valve cover gasket(?)
    my question is: is that my problem? how did it happen and how Expensive/hard is it to fix?
    thanks.
    Strategic Alpine Command:...sig loading
  • RedHoodRidah
    • Feb 2006
    • 1096
    Yup thats your issue. Just buy the valve cover gasket set and change it and good luck on the valve cover threads not needing to be heli coiled or re threaded
    92 Granite Silver Vert
    M60B40 5spd
    • TooTall90
      • 338
      good to know.
      any idea on how this happened and roughly how much is it gonna cost?
      • FredK
        • 14759
        Like $25. Valve cover gaskets go bad. They're constantly splashed with hot motor oil. They get brittle and lose their ability to seal.
        • TooTall90
          • 338
          doesn't sound too bad.
          sorry for the chain of questions but hopefully this is the last one. should i send this to a mechanic to be done or is it simple enough for me to tackle on my own?
          im replacing part #3 correct?
          • FredK
            • 14759
            When you replace a valve cover, you generally replace 3, 4, and 5, plus the required quantity of #9 (these are like 40 cents each). A valve cover gasket kit will include 3 and the required number of 4 and 5.
            • E30SPDFRK
              • 5693
              Its real simple. Just unbolt the cover and replace the gasket. Be sure to clean both the mounting surfaces of the head and the valve cover, and be sure not to drop anything in there.
              Byron
              Leichtbau
              • TooTall90
                • 338
                thanks for the info. i might wait for warmer days though.
                oh and E30SDPFRK is that a passat lip i spy in your sig? looks like it turned out decent. i still have one that Wally gave me laying in my garage lol
                • E30SPDFRK
                  • 5693
                  Yeah it is. It fits pretty good, but it sticks out about an inch under the fogs because of the way it is shaped. I tore it off on a curb though :(
                  Byron
                  Leichtbau
                  • 3bvert
                    • 1032
                    some people at this time, also paint the v/c cover, which will add time for cleaning etc
                    but the main thing is to be gentle tightening the v/c bolts remeber your going into soft metal
                    mine needs 2 heli-coiled, by p.o
                    but its not leaking, so Ill wait until I need a new v.c g
                    • TooTall90
                      • 338
                      thats the price of being low huh Byron? lol
                      and i agree with you 3bvert, im gonna try to do all that VC paint and cleaning all at once. thats why i want to wait till it gets warmer out.
                      there shouldnt be a problem driving around like this for a little while longer right?
                      • RedHoodRidah
                        • Feb 2006
                        • 1096
                        Just replace it. Bring that shit to my house Ill bang it out if youre going to take it to a shop.
                        M60B40 5spd
                        • TooTall90
                          • 338
                          good shit wally ill def do that then. once i get some free time and the parts ill hit u up.
                          • RedHoodRidah
                            • Feb 2006
                            • 1096
                            Sho nuff.
                            M60B40 5spd
