m42 main thrust bearing?
  • Simon S
    • Oct 2004
    • 3758
    I’ve done some research and am having a hard time gathering information about the main thrust bearing in an e30/m42 motor.
    I understand that half of a bearing shell was used and it presents a fail point in design.
    How does the main thrust bearing differ from rod bearings?
    Why can’t I find part numbers for a main thrust bearing in realOEM ?
    Where is the main thrust bearing?
    While yes – replacing a main thrust bearing(s?) typically is done during a full rebuild – is it possible to replace a main thrust bearing while engine is in the car?
    Any first or second-hand knowledge on stories related to the m42 main thrust bearing?
    Thanks for any input.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
  • KenC
    King of Kegstands
    • 14396
    It's called a "guide bearing" on realoem.
    It's the crank bearing between #3 and #4 cylinders.
    Replace while the engine is still in the car? I guess you could pull the bearing cap off and put a new piece in there...
    Slight shifting of the crank from a worn out one is the issue with it.
    Originally posted by Gruelius
