Pelican Parts Shifter Bushing Kit
  • stegosaurus
    • 367
    Has anyone used the shifter bushing kit from pelican parts? I was comparing the part numbers to RealOEM and while it covers most of it, a good amount of stuff is left out.
    Did you buy their kit and find that it didn't have everything that you needed? What else did you need?
  • BlackBMWs
    • Aug 2009
    • 12
    Just installed the Pelican kit in my 91' 318ic. It was only missing one of the yellow plastic washers. (3 instead of 4) One additional Item I did pick up that was not in the kit was a shift selector rod seal.
    Once it was all installed, with a Z4 3.0 shifter, what a nice difference. The notchiness takes getting used to, but very nice shifting.
    1999 540it - Jet Black/Sand Beige
    1998 318ti - Schwartz/Anthraz
    1997 318ti - Schwartz/Anthraz
    1995 318ti - Alpineweib/Schwartz
    1994 325i - Bostongrau/Sand
    1991 318ic - Schwarz/Anthratz Stoff
    BMWCCA# 160411
    • stegosaurus
      • 367
      Was the washer part # 25-11-1-220-439? Do you have the pn for the selector rod seal?
      • BlackBMWs
        • Aug 2009
        • 12
        Yes for the washer, 23-12-1-282-394 for the selector rod seal, although I encourage you to cross check for your tranny. Mine is on my 91 318ic.
        RealOEM shows it as a 240 (Getrag?) but, I've yet to confirm.
        BMWCCA# 160411
        • stegosaurus
          • 367
          Yeah, Getrag 240. I have two, the one I'm working up has under 65k so it should be nice when this is all done. Thanks for the P#.
