Slight Idle irregularity.
  • M42Power
    • Dec 2009
    • 519
    Since i bought my boat, it had a problem that did'nt disappear with the head rebuilding, When it is warm, the idle has some tiny variations.
    This problem only produces when it is warm and it is slightly annoying.
    The car was connected to the pc and the o2 sensor was pointed as guilty for an slight instant, but it could be the idle valve. So i am a bit clueless about this problem and i could use a little bit of help.
    Originally posted by kendogg
    Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
    OG RACECAR
  • rafiki
    • 245
    The m42's tend to have a lot of vac hoses start to crack over the years. Under the intake runner/ manifold is where those hoses are.
    But before replacing hoses you can try to disconnect your Idle control valve(icv) and cleaning it with some electric cleaner, or whatever you choose.
    that MAY help.. cant hurt.
    if you have the time and effort, i think you should go about doing this
    • M42Power
      • Dec 2009
      • 519
      http://www.m42club.com/forums/showthread.php?t=2742
      I have already replace all the hoses under the manifold, they were all cracked.
      I believe the were called the ''octopus hoses''.
      When the head was taken off, all the components attached to the head were cleaned and replace, if so was necessary.
      OG RACECAR
      • e30_3I8I
        • Sep 2009
        • 305
        im having the same problem.. i dont know what it is though... when i start my car it idles fine.. and once it gets warmed up the idle does to 950-1200 everytime i put it on neutral. it really annoying
        my project
        http://r3vlimited.com/board/showthread.php?t=164374
        • ck_taft325is
          • Sep 2007
          • 6880
          ICV or AFM possibly? OR, check under your wiring panel (right under the windshield) and see if there's a wire that pokes out. Is it plugged in? Unplug it. It's the "run like shit" wires.
          They are for the CAT or non-CAT versions of the m42 (US spec upos to EU spec cars).
          Need a part? PM me.
          • M42Power
            • Dec 2009
            • 519
            Mine is not so bad, it only goes from 900-980ish rpm's
            OG RACECAR
            • M42Power
              • Dec 2009
              • 519
              I am gonna check it, but my AFM seems to be fine as the car pulls great.
              OG RACECAR
              • ck_taft325is
                • Sep 2007
                • 6880
                Check the "run-like-shit" wires. I'll try and find the diagram that points it out so you have more of an idea of what I'm talking about.
                Need a part? PM me.
                • getouth
                  • Jan 2010
                  • 3343
                  I am having the same issue. It suck's that i spenk 2k;s in the car an it doesn even idle right. However it runs great after 100k rpm's ?????
                  FEEDBACK:
                  http://www.r3vlimited.com/board/showthread.php?t=316212
                  BMWCCA #398608
                  IG @yagayo38
                  "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
