well every since i swapped the engine the engine has been misfiring...it doesnt bog, when idling it misfires all the time...i dont know what to look at?, i did notice like a few drops of oil in 2 spark plug holes i dont think that much could cause a misfire ?????
also im going to check the plugs...ignition wires were working fine on my old engine...also when i rev the engine about 2k more like 1800 rpm it starts to shake (engine) after it passes 2.5k rpm it stops...
anything to look check?? injectors? fuel pump?
what else could cause a misfire? o2 sensor?
also the engine was originally from chigago could the change in temperature cause some sort of problem?
i also changed parts from my old engine..also has a brand new thermostat because it was overheating...
