WHat's this sound?
  • Vlad_318iS
    • Feb 2007
    • 151
    WHat's this sound?
    SO, my car (m42) has been sitting for over 6months. I finally started it up and I don't think this is a healthy sound.
    I am not sure what it can be. I have ideas but I am no expert. SO, I NEED YOUR HELP!!
    the high pitch is the clutch bearing/release bearing while the loud BANGING sound is ?????
    the banging sound is actully louder and "thud" like in person...
    here is a vid: http://s898.photobucket.com/albums/a...weirdsound.mp4
    THANKS!!!
    http://vnmi.mybrute.com
    :razz: 1991 Alpineweis 318iS
    :arrow: 1991 Briliantrot 318i
  • E30Idea
    • Mar 2007
    • 2196
    Lifters
    ** Lot's of M20 turbo parts for sale.**
    Turn key track car.
    http://www.r3vlimited.com/board/showthread.php?t=222066
    • Vlad_318iS
      • Feb 2007
      • 151
      Originally posted by E30Idea
      Lifters
      ok...what happened to them? why are they making this sound? what can i do?
      • Adrian_Visser
        • Jun 2006
        • 2823
        One is sticking or not filed with oil yet. Run the engine longer and it should go away.
        '89 Alpine S52 with goodies
        • Vlad_318iS
          • Feb 2007
          • 151
          is it possible that it can do some damage? if so, is there a way I can manually lubricate it so it wont be sticking anymore.
          i am really nervous running it with that sound...
          all help is greatly appreciated.
          • greanthumb
            • 1992
            sounds like just a stiff valve train bro... give it some fresh oil. then just let it run for a few minutes(up to operating temp)then give it a drive around after a few miles the sound should be going away or gone. good luck. btw- it shouldnt cause any damage just make sure you dont r3v it to high until it lubes back up.
            91 318is...DD:finger:/85 325es SOLD/91 318is RIP
            Originally posted by naplesE30
            Must stop clicking on Norwegian threads. Makes me wanna punch my car in da mouf.
            Originally posted by einstein57
            My tranny sounds like a blender full of walnuts. So I added sound deadner to the tunnel and put in a louder stereo. Am I doing it right?
            Castro Motorsport/E30 specialist
            North Hollywood, Ca. 818 310-2497
            • KenC
              King of Kegstands
              • 14396
              Yeah, sounds like your lifters aren't fully pressurized... or possibly your chain tensioner too. It's not going to hurt anything.
              I'd change the oil though for sure, and make one of the quarts a nice synthetic ATF. It has a lot of detergents and will "clean" the gunk out of the lifters.
              I'd run it at varying RPMs for at least 15 minutes after that. Noises should subside.
              Originally posted by Gruelius
              • greanthumb
                • 1992
                ^^^that works too^^^
                • E30Gus
                  • Jun 2008
                  • 781
                  would the ATF be a good idea for an engine that is pretty gunky (bottom end)? The top end was rebuilt and the engine will be going in the car soon. Wondering if this is good assurance for cleaning all the oil passages.
                  • KenC
                    King of Kegstands
                    • 14396
                    It's a 5.3 quart engine, so replacing one quart of motor oil with a quart of high quality synthetic ATF isn't going to compromise your engine lubrication. The ATF has a really low viscosity, however, it contains a ton of detergents that will help bust the grime out of your lifters and chain tensioner.
                    I'd run it for a couple thousand miles and then go back to straight oil during your next oil change.
                    • Vlad_318iS
                      • Feb 2007
                      • 151
                      thanks!
                      Thank you guys for all the help!
                      I read some more about stuck lifters and decided to go with...
                      Marvel Mystery Oil.
                      I added some to my fuel and started it. In about 3-5 minutes the sound went away!!!!
                      I was soo relieved.
                      Thanks for all the suggestions and help!
                      • harv
                        • Nov 2004
                        • 555
                        You needed to add it to your oil. Adding it to your fuel will help the fuel system. Your lifter noises went away on their own. MMO is great stuff
                        John
                        The Revolution will not be televised.
