Son of a... *Brutal Damage Inside*
ouch
rare for this to happen,
with one exception, that the head was done and the cams in their towers were not torqued down in sequence and carfully. the cams will crack if not done correct. then high revs, low oil pressure plays thier toll and snap
usually this happens pretty early after a head , if done wrong
but I guess could happen anytime if a crack is there
hopefully, when it snapped the revs were down, and the engine shut down right away, cause if a valve was left open on a compression stroke, your looking at an overhaul, possible pistons, but at lesat a few bent valves
good luck
is the latter head just a pull and play ? I thought there was some other changes that had to happen, maybe thats whole motor.
If you old head is not cracked, dont trash it, keep it, sell it, whatever. Ive seen early m42 heads sell for several hun
whats a e36 m42 head go for these days.....just curious
and of course great time to get rid of throttle body heater crap if you havent already
