Ok, so I did the whole mess under the intake thing,, and because I'm special I didnt drain coolant prior. I replaced the coolant tube and all. (yes picture a fairly large mess, luckily caught by an old car cover) Now, I added coolant, started the car up, and it doesnt seem to have an overheat issue (havent driven it, but just running in the garage) but I no fluid comes out of the bleed screw either....It seems that there is enough fluid in the overflow, but Im not sure.
How high should the coolant level be while running?
Do i need to continue to add until fluid comes out of the bleed screw?
Am I special or lucky or perhaps I'm doing something wrong?
