check water pump
I want a quiet engine!
Originally posted by M42Technik View PostI'm currently having similar symptoms, didn't want to start another thread. Just recently started running rough from idle to 2,200 then seems to smooth out. From reading here and there I gathered its usually the chain tensioner if it is at lower RPM's. New timing chain tensioner is on the way, but I'm gearing up to replace the guide rails, it sounds like a diesel. I'll post a video soon...
Originally posted by G-Man View PostMy M42 timing chain tensioner failed at 129K and my engine suddenly became good for only a boat anchor. The new timing chain tensioner is a M44 tensioner if I'm not mistaken.
G-Man
Originally posted by M42Technik View PostWell it was running quite smoothly until this, now it sounds like a diesel. Anyways hopefully the new one will arrive soon as I don't have another car and I need to get to work, though it is only 3 miles away. I'm just praying its rectified with a new tensioner, rather than being a more serious problem.
Here is a soundclip, this was after warming it up a bit. You can hear where the rattle or noise dissipates at 2200-2400, when the revs are coming down:
Soundclipsigpic
HyperWerkz
89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi...592whp
" enjoy the show "
When I bought my car it had this exact same noise w/ 118k on the clock. I replaced the timing chain tensioner piston with the updated version in less than 5 min. with a single 19mm wrench and the problem went away without returning.
tensioner piston p/n 11311743187 $39.11 from autohausaz.com
if you've got a higher milage engine other suspect timing components apparently are:
timing chain tensioner p/n 11311727342 $97.64 from autohausaz.com
timing chain guide p/n 11311247470 $53.44 from autohausaz.com
Remove your valve cover and take/post some pics of your cam gears and everybody will see where you stand in your quest for a quiet m42.
Run these part #'s by Blunt because his parts prices are awesome.Last edited by Ryann; 12-22-2010, 09:23 PM.
Originally posted by M42Technik View PostReplaced it. Still loud and diesel sounding, definitely not like before. When I pulled out the old tensioner I found a little piece of black plastic.
Time to replace the chain. :(
Should I even be driving with it this way? Or am I going to do serious damage?
I got SUPER lucky. I made it the 1500mi home and when the chain guide finally split in half it didn't jump time enough for the pistons to hit the valves. I wouldn't recommend chancing it.
Originally posted by vegaskyle View Posthttp://r3vlimited.com/board/showthread.php?t=185559
Fuck there goes my Christmas money. Looks like I'll be walking to work for a while!
Now to buy parts and try and get a local friend to help out, I don't have another car to drive and this is my daily!Reminiscing...
Originally posted by M42Technik View PostSaw this thread, was hoping my M42 wouldn't be sharing the same fate.
It's not too hard of a job. Prior to this I had never done anything harder than replace a starter on an old Nissan. I'm not experienced or skilled in auto repair but I'd like to think I'm mechanically inclined and capable of following directions.
The e36 Bentley does a good job of describing the process. I also used Brendan Purcell's writeup. The only part I was worried about going in was the crank bolt. I went with the block of wood/starter method and it worked like a charm. I'd highly recommend it. For the crank locking tool I used that piece in the tool kit you use with the spark plug tool (a long chrome dowel with a grey plastic handle) but I think a drill bit or screw driver would wok fine too. I also didn't have a cam locking tool which turned out to be fine. The plan going in was to use a pair of crescent wrenches and duct tape/zip tie them together. My chain jumped 1 or 2 teeth and it was out of time at TDC so I wouldn't have done any good. I just used a wrench on the back of the cams while I tightened the cam bolts. Then used a level to check they were parallel to each other. The first time I nailed it in about 2 min, after taking everything apart to fix a problem the second time took about 20 min.
The only hard part aside from having to do it all twice because of a little fucking piece of chain guide was dealing with the AC compressor and bracket. It was a pain in the ass to get on/off just to reach 2 bolts on the lower cover. The crank seal was also kind of hard, I think it says to "tap" it in, took more than a tap for me to get it in there. Had I not been so easy on it to start with I would have been a 5 min job.
If I didn't have to go back and redo everything I'd say it took me 6 hours start to finish. It would have gone quicker if I had more tools (different socket extensions and u joints would have helped) and wasn't so methodical (think zip lock bags with contents numbered and labeled). If you get someone to help you it may speed it up a little, but honestly if I can do it anyone can.
I think I spent just under $400 and replaced a few things that weren't absolutely necessary. Depending on what you need/want to replace and how much you shop around you should come in somewhere around there.
Thanks, that makes me feel better about tackling this job. I just wish I had garage space and it wasn't 20 degrees out.
I'll be speaking to blunt once I have a parts list (going off Brendan Purcell's). I'll probably end up getting it all ahead of time, I don't want to open the timing case covers and see I need an extra part I have to wait to get shipped to me, and better replace it all in one shot. Going to do the water pump and thermostat too while I'm in there.Reminiscing...
^why not just ziptie it up out of the way so it is not hanging. Or if sulfide won't work put something underneath to support it.
As for people saying the m42 is not a quiet motor when it was new. I am having a hard time believing that since my m42 is almost silent after a timing, and topend rebuild which included new hydraulic lifters. Will put up a vid soon.sigpic
