bought a 91 318i, have an issue.
  • 2.5-12
    • Jan 2010
    • 1814
    I bought a 91 318i, car needed a fuel pump which was included brand new in the trunk, I popped it in, cranked her 4-5 times for 6 seconds and fired up. took her for a drive and aside from a hideously loud exhaust, drove well.
    the problem came later in the day, I started it up, runs great and idles good, but when I started to back up (car is a Manual) revved it up to 1500 just fine but when I started to let out the clutch, the car hesitated, I have to put the clutch back in to keep the engine from dieing. this happened several times and in forward gears too.
    if I push the gas hard, it'll sputter like mad then give me a little burst of power then stutter. it will still idle just fine but under any kind of throttle load she doesnt run well.
    any thoughts? I think it threw a CEL so maybe I should stomp test it.
    TPS? Vacuum leak? dirty ass fuel filter? any input is appreciated.
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
  • drumad
    • Aug 2009
    • 1700
    Since you just got it, you should probably go ahead and simplify the vacuum hose mess under the intake and delete that tb heater. Solved my idle issue. Clean the iacv also.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • 2.5-12
      • Jan 2010
      • 1814
      I am new to the M42, been in, on around M20s a lot but this 4 banger is new to me
      be heater hoses, you mean coolant throttlebody lines, or?
      anything in particular I should be doing?
      Thanks much
      • drumad
        • Aug 2009
        • 1700
        Thanks much
        Go on google and search for "mess under the intake" and you'll see exactly what I'm talking about. Easy enough job.
        I'd explain a bit more but I'm on my phone :(.
        2008 335i - n54b30
        1991 318i - m52b28
        • Charley
          • 396
          mess under the intake: http://www.m42club.com/forums/showthread.php?t=2742
          • Eecen
            • Jun 2010
            • 1235
            Try doing this:
            Post #6 http://www.m42club.com/forums/showthread.php?t=7757
            m42club is going to be your friend w/ this engine...try searching on there
            • 2.5-12
              • Jan 2010
              • 1814
              Thanks all, been reading on that site about Medusa. I shall get in there and take care of that pronto-like.
              • Eecen
                • Jun 2010
                • 1235
                Originally posted by Eecen
                The mess under the intake is always a good thing to take care of, but I can...more or less...guarantee it won't fix your hesitation problem.
                • tonywonder
                  • Sep 2009
                  • 1688
                  try using some fuel cleaner and see if that helps. maybe its something to do with your fuel system.
                  i would also check the plugs, plug wires, coils, etc. and of course check for vacuum leaks.
                  how many miles on the engine?
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    212k miles
                    has new plugs and wires
                    ill dump in some fuel system cleaner as well as some fuel soon, the wire, I'll have to look and disconnect it if its connected, as far as the mess under the intake, I'll see what I can do this weekend.
                    • bmwm42
                      • 6300
                      Vacuum issue for sure check line to icvlocated btwn intake manifold and firewall
                      Originally posted by bmwm42
                      PNW vulture pm me for parts
                      Strategic nw e30 command
                      • dkbmxer002
                        • Nov 2007
                        • 1389
                        change the fuel filter, fix/check the mess under the intake, clean the iac and check a thread on m42 club about a wire up on the fire wall.
                        • 2.5-12
                          • Jan 2010
                          • 1814
                          turned out to just be old fuel.
                          • phoenix_III
                            • 1
                            That's great! Thanks for posting a follow-up/conclusion. Should also run some cleaner/change fuel filter now!
