Vertically Mount an M42
  • AndrewBird
    The Mad Scientist
    • 11898
    I'm trying to put an M42 in my MG, however, I'm running into some clearance issues. Most of my issues will be resolved if I mount the engine vertically instead of diagonally (valve cover level, not intake level). Obviously this makes the oil pan not work, but I can make a new one, along with a new pickup.
    Is there anything else I'm not thinking of that would be an issue?
  • MonkeyMadness
    • 3251
    Oil drain back in the head????
    sounds like a fun project....!
    • E30SPDFRK
      • 5693
      Yeah oil drainback could be a problem. Also the front coolant pipes will be off by a bit, which isn't that big a deal but may cause bleeding issues.
      Byron
      Leichtbau
      • AndrewBird
        The Mad Scientist
        • 11898
        I thought about the oil drain back, but as long as it is level, I think it should be fine. I haven't pulled the valve cover yet to look. Are the drain galleries on the lower side of the head only?
        • vegaskyle
          • Sep 2009
          • 121
          I love your MG. My grandpa has owned about 3 MGB's in my life time and they are fun. I think it would be so cool if you could get this to work.
          • E30m42cab
            • Aug 2009
            • 190
            Even something as simple as measuring your oil with the dipstick becomes a bit of a guessing game too. If you're using the M42's tranny, you'll have to keep the tranny level, which means making new tabs to bolt her up.
            • AndrewBird
              The Mad Scientist
              • 11898
              Dipstick would be modified to work with the new oil pan to read correctly, so that isn't a problem. Tranny could be an issue, but at this point, I'm not sure if it will be rotated enough to matter. I still have a lot of stuff to look at and figure out though.
              • MonkeyMadness
                • 3251
                Hay! Hay you!
                any update?
                • SpoolnDaapex
                  • Jan 2010
                  • 150
                  Have you thought about swapping a different motor? Seems like a lot of work when there are probably other options.
                  M42: Because 110 feels like 140 :finger:
                  • carnurd
                    • Jul 2009
                    • 110
                    Almost perfectly level, but then again its dry sumped....
                    1991 BMW 318is Track Car-NEEDS ITBS AND STANDALONE!!
                    1997 BMW 328i Daily Driver-like buttah..
                    • Massive Lee
                      • Sep 2006
                      • 6785
                      Transmission angle?
                      You can make a flat bottomed pan and dry sump the engine. You then can lower the motor another inch or two.
                      massivebrakes.com
                      • carnurd
                        • Jul 2009
                        • 110
                        Tranny angle would need to be corrected with either some type of adapter or a whole new bell housing..
                        • Massive Lee
                          • Sep 2006
                          • 6785
                          ^^^I think an M20 bellhousing fits the M42 block. To be confirmed. If so, then get one from an early 528e with two-piece tranny. You can cut the end of that bellhousing where it bolts to the tranny (four bolts), and fabricate a new one, that will be rewelded at the proper angle.
                          massivebrakes.com
                          • george graves
                            • 19996
                            Rotate the motor, but raise one side of the car up with super long springs.
                            Originally posted by Matt-B
                            • Stephen
                              Шлем ишака
                              • 10774
                              ^ or bag it and just raise one side if its showing symptoms
