i just picked up a 91 318i w/ 230k on it. what weight oil should i be using and what spark plugs do you guys recommend?
..it's going to be a DD. It also has a starting(half dead battery) and idling problem, which i think maybe a vacuum problem or a fuel problem. It's leaking fuel from the line comming from the filter to the engine. Once it's in the upper RPM's it doesn't die so i dunno. I have a new filter and fuel line so i hope these fix the problem.
