Hey There,
I'm new here, but some of you may recognize me from bimmerforums or m3forum where I've been a member for some time. I've had an E36 328is and an E46 M3, but just today bought my first E30, a 2 owner White on Tan 318is in excellent condition...except for its engine.
As far as I can gather, the car has been sitting for about a year due to an engine problem that the PO just didn't want to deal with. Apparently it was started yesterday as another party inspected it, and it will start and run, but it sounds terrible, as though there is a clattering clanking noise from the front of the engine.
According to the seller, the car has received a new water pump, radiator, tstat and hoses just before it sat, as well as an M44 timing chain tensioner around 40k miles ago (227k miles now).
This along with my research searching through the forums has me thinking that the chain guides are gone and that the chain itself is probably in need of replacement. Seem like a plausible explanation?
I'd like to keep the M42 in there if possible, and keep the car basically stock(maybe switch to a Z4 shifter assembly and buy the stock IS lip). I have the M3 for speed, so this would basically be a nice peppy daily that I could drive for a few months and then give to my father. As such I'm shying away from a 24V swap and would just like to rehab the M42.
My current plan of action as soon as I receive the car later this week is to:
-Replace Battery, Plugs, Plug Wires
- Pull plugs and attempt to rotate engine by hand to check for valve to piston contact (i'm afraid the chain jumped and fubar'd the pistons)
-Perform compression test on all for cylinders to confirm presence/absence of contact. Sounds like the numbers should be around 200 on all four cylinders?
- Drain oil, drop Lower pan, retighten and locktite all loose bolts on upper pan. (How common is the issue where the pan gasket shifts? Really do not want to deal with spun bearings or damage due to loss of oil pressure)
- Assuming everything checks out so far, dump coolant, dissassemble front timing cover, replace all four sprockets (Crank, idler, 2 camshafts), 4 chain guides, tensioner, related gaskets.
-Reassemble, fill with oil and coolant, replace trans and diff fluid, pray it works?
I'm not a guru on these engines so any criticism on this plan would be MUCH appreciated. I'm crossposting over on M42club so my apologies in advance to the many of you who will probably see this twice.
Additionally, is there any sort of loan system for the camshaft and crankshaft lock tools? I'd rather not spend close to a hundred dollars for tools I only plan on using once, and i'd be more than happy to compensate someone for letting me borrow them.
This is the parts list I compiled so far:
Upper Timing Case Gasket Set 11141721919
Lower Timing Case Gasket Set 11141721802
Lower Oil Pan Gasket 11131709815
2X Camshaft Timing Sprockets 11311721887
Crankshaft Timing Sprocket 11211247338
Woodruff Key 07119951480
Idler Sprocket 11311727569
Upper Chain Guide/Slide Rail 11311721641
Lower Chain Guide 11311721419
Passenger Side Chain Guide/Tensioner 11311727342
Driver Side Chain Guide/Tensioner 11311247470
Piston Type Tensioner 11311743187
Timing Chain 11311247160
Crankshaft Seal 11141439570
Valve Cover Perimeter Gasket 11121721876
3X Valve Cover Spark Plug Gasket 11121721476
Valve Cover Spark Plug Gasket (Lollipop Shape) 11121721475
Which should hopefully cover everything? Is Tischer the cheapest place to shop for it all as with the E46?
Thank you so much for all your help in advance, I really appreciate any guidance on getting this thing running.
