No start!! Dont know what it is?
  • gannett43
    • Jul 2010
    • 47
    Completed the mess under the intake and checked all my hoses and made sure everything was wired correct. Note my car has been sitting for about 8 months now, hasnt been started in about 5 months. My battery was ok before but with a jump would start up. I let it run for about half an hour and shut it off. When i tried to start it right after i got nothing almost no battery, couldnt even get the windows up.(this was 5 months ago.) Now im ready to start it up and i just hooked up the old battery to get jumped, let it get a ten minute charge and tried to start it. Turned the starter over but it was like it didnt have enough power to turn it over all the way. It would try try and then stop. Im hoping its only the battery and not a fuel or spark issue. it ran fine before was put in the garage. Any ideas?
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Fully charge your battery (24 hours) then try again. If you still have the same problem it's time ot start looking elsewhere. But 10 minutes on a charger won't cut it.
    • gannett43
      • Jul 2010
      • 47
      Will do, hope to christ this thing starts after that.
      • gannett43
        • Jul 2010
        • 47
        Trickle charged the battery all night and day, hooked it up and turned the key. Took a while for fuel to to the get the rail but when it did the garage was filled with sweet sweet noise. Idles happily at around 700 rpm.
        • fiftytakedowns
          • 2460
          9 times out of ten no start problems are crank position sensor.
          which I happen to have a spare one.
          [/url]
          Team USA Wrestling 67KG
