Torquing Order for Valve Cover
  • freeride53
    • 11972
    Does anyone know it or have a diagram?
    I'm about to go ahead and put mine back on (m42).
    Already have the wrench set at 10 nm / 89 in.lb
    Thanks!
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • KenC
    King of Kegstands
    • 14396
    Doesn't matter. Just make sure they're not too tight. Just tight enough to keep air out and oil in.
    Originally posted by Gruelius
    • Paradox
      • Jul 2010
      • 337
      middle ones first, then diagonally across till you get to the ones on the ends - just like the head - completely not required -
      but if you like anal...umm I mean if you are anal...you would replace the studs and bolts with new OEM items and then follow the above sequence
