What were the signs before your fuel pump quit?
  • harv
    • Nov 2004
    • 555
    A few times my otherwise good running M42 just quit on me. At idle, twice in the last 6 months. Wait a few seconds and then it will start right up and run perfect. I have all the stuff for the mess under the intake but haven't gotten in there yet. It's on my to do list. I would think if it was the fuel pump, it wouldn't just do it at idle.
    Anyway just thinking out loud.
    John
    The Revolution will not be televised.
  • selturk
    • Dec 2008
    • 1197
    does the pump work very loud? that's a sign of a pump which is about to fail.
    • VoskaOhrid
      • Jul 2010
      • 37
      if you hear the pump humming then its probably working. check for vac leaks and also look into your ICV clean that out! take it from there
      • harv
        • Nov 2004
        • 555
        Thanks for the info. The last time it did it I cleaned out the ICV but it was pretty clean to begin with.
        I don't hear the pump at all, even when it's running.
        I don't think it's ignition since I can watch the tach as it dies. In other words the tach doesn't just die and the moter dies at the same time.
        Hmm..
        John
        • StereoInstaller1
          GAS
          • 22679
          Pull the cover off the fuel pump (underseat cover) and listen, then whack it if the car dies, see if it starts running again
          Closing SOON!
          Thanks for 10 years of fun!
          • harv
            • Nov 2004
            • 555
            The problem with that is I might have to wait another 6 months for it to quit. Man, thats a long time to hover over the tank with a hammer in hand.
            Back in my Volvo days I had this 242 and the pump started pulling more and more amps. eventually the solder let loose on the fuel pump relay. As I was in school and had no cash, I re-soldered the relay and left the cover off and let it dangle by the kick vent. It would burn my knee while AutoXing in shorts
            John
            • VoskaOhrid
              • Jul 2010
              • 37
              To check the fuel pump go by the fuel filter and take off the hose on the back end connected to the fuel pump. Have something by so u don't spill fuel allover and have someone start the car. If the hose is spewing out fuel then the pump should be fine
              • harv
                • Nov 2004
                • 555
                I'm hip,
                Thanks
                John
                • StereoInstaller1
                  GAS
                  • 22679
                  John, Kim and I took a road trip with the back seat looses and that hatch open, as every time we stopped, it was a battle to get the car running again.
                  While the car is cranking over, bop the thing
                  Closing SOON!
                  • harv
                    • Nov 2004
                    • 555
                    I'll remember that for my trip to Vintage in WS!
                    Maybe I should just buy a new pump and squirrel it away.
                    John
                    • StereoInstaller1
                      GAS
                      • 22679
                      Time between first fail and full fail was over 2 years, well over 20,000 miles
                      Closing SOON!
                      • harv
                        • Nov 2004
                        • 555
                        Ah that's what i like to hear. Far off impending doom!
                        John
                        • Matt-B
                          The Waffler
                          • 3856
                          I would be driving, and the car would die, but before it died completly, surge like it got a boost of gas, and on start ups, crank crank crank crank run.....die
                          turned out my wires to pump were loose, So I got new ones, and new connector end, problem fixed
                          • harv
                            • Nov 2004
                            • 555
                            It did it again. Not ignition as the tach kept working throughout the whole thing. I thought I was going to be stuck on the side of the road but key off and key on it worked and ran fine. Hmm..... kinda like a reset. I think it's something to do with the IACV and the mess under the intake.
                            John
                            • StereoInstaller1
                              GAS
                              • 22679
                              You should pop your seat loose and pull the pump cover for now so you can hear it.
                              Oh: turn the damn stereo down, too.
                              Closing SOON!
