What kind of bleed screw is this?
  • keada714
    • Apr 2011
    • 424
    My bleed screw broke today and I need to find a replacement. I already went to a bmw dealer and they didn't carry it. Can someone please tell me whats the part number for this screw!!
  • mr.vang
    • 4371
    realoem.com should have the part number
    • Matt-B
      The Waffler
      • 3856
      You need #8, just look around a bit more first
      part # 17 11 1 712 788
      • keada714
        • Apr 2011
        • 424
        I've tried using the "original bleed screw" that I bought from BMW but it does not work. It is a little to big for this radiator. The reason why I posted this up is because I been struggling to find the right screw for this. Right now I rigged up a temp screw to keep it from leaking. The thread pitch for this screw is 8x1.25. So does anyone have an ideal on what screw to use or any other information in order for me to get the correct screw..
        • Matt-B
          The Waffler
          • 3856
          the 1 from bmw will and should work
          • keada714
            • Apr 2011
            • 424
            I've tried the one bmw gave me as well as the one I pocketed from the junk yards.. I had to get a 8x1.25 bolt with an o ring to seal it up.. It works fine but I would like to replace it with the correct bleed screw.
            • Gooch
              • Dec 2006
              • 1674
              Take off the cover plate and see what's going on under there. That is not the OEM bleed screw because the OEM one sits flush with the cover plate. Maybe the previous owner stripped out the threads and put something together to make it work?
              '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
              '87 535i - Vacuum brake conversion [SOLD]
              '93 525iT - 5-speed swap - 320k and counting
              '09 328xi - 6-speed
              • keada714
                • Apr 2011
                • 424
                which cover piece are you talking about? The black piece that is held on by the two screws?
                • keada714
                  • Apr 2011
                  • 424
                  Dont think the bleeder has been tampered with it, since the bleed screw is a smaller than the "bmw screw". I can re tap it so the original bmw screw can fit but It wont sit flush therefore i'm afraid it wont seal correctly. I think im going to just stick to my homemade screw..
                  • Gooch
                    • Dec 2006
                    • 1674
                    Yes, the piece held on with two screws.
                    Honestly if the bolt and o-ring works, just go with it.
                    '09 328xi - 6-speed
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      I actually bought a metal bleed screw from Pelican Parts. They're cheap and don't get brittle with heat, so I'd go that route.
                      Project M42 Turbo
