M42 idle issue HELP!
    I recently needed to replace the VC gasket and chain tensioner, so I decided to check out the vacuum hoses for any cracks and whatnot. I might've fucked up the fpr line that goes to the rear of the throttle body. Anyone have a part number? If need be I'll take photos of said line, it's real small almost insignificant but it resulted in awful idle which i never had before. I didn't mess with the ICV at all btw.
    1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
    No E30 Club
    Its P/N 11 72 7 545 323 but its just standard vacuum line - looks like .07" (1.8mm) inner dia but 1/16" will probably fit.
      its a simple vacuum plastic tube/line that you should be able to pick up at your local parts store.
      and just in case, its part #11:
      Attempts to get back in e30 world failed - hello e39! ;D
      '91 318is - sold
      '95 318is - sold
        Thanks fellas, you guys are great.
        Imaginary rep for you two +1
        No E30 Club
