UPDATED WITH NEW PROBLEM AT THE BOTTOM
so my problems started yesterday when i was replacing the radiator. finished that up with no problems, then came time to bleed. proceeded with that and all was going well, got most of the air out but for some reason i decided to turn the car off to check somthing. went to start it up less than 5 minutes later and its a no go. cranks strong and sounds like it wants to catch but wont. it just keeps cranking. i didnt chang anything in between that time i had it off.
so after testing and checking everything i could think of and found through searching the web i decided to leave it alone for the night. get up this morning and get ready to continue and she starts up just fine.
i let her run for a few minutes and turn it off. a couple seconds later i go to turn it on and the same crank but no start. im so lost right now the only thing i can think of that i havnt checked is fuel and the crankshaft position censor. it also makes a noise after i stop trying to crank as if something is stuck.. idk how to descibe it but it think its an electrical noise.
i took a sound clip of it this morning and as soon as i figure out how to post it ill add it in here. anyone know of or had anything similar?
i do need to replace the hoses for the nest under the intake, valve cover gasket also needs to be replaced but they arent to the point of extremes or no start.
i let her run for a few minutes and turn it off. a couple seconds later i go to turn it on and the same crank but no start. im so lost right now the only thing i can think of that i havnt checked is fuel and the crankshaft position censor. it also makes a noise after i stop trying to crank as if something is stuck.. idk how to descibe it but it think its an electrical noise.i took a sound clip of it this morning and as soon as i figure out how to post it ill add it in here. anyone know of or had anything similar?
