M42 idling at 4500rpm.
  • willworkfore30s
    • Aug 2011
    • 1090
    Just finished putting in an m42 from another car with ~150k on it.
    Crank the car, engine revs to 4500 and stays there.
    Any ideas on whats causing that? I know I have an exhaust leak around the exhaust manifold, could that cause it?
  • KenC
    King of Kegstands
    • 14396
    Is your throttle cable adjusted correctly?
    Originally posted by Gruelius
    • willworkfore30s
      • Aug 2011
      • 1090
      Its possible that its not, however when I do not have any pressure on the pedal the throttle does seem to be all the way closed.
      I do not know the proper way to adjust the cable. I just tried to leave it the way it was before and hook it back up.
      • KenC
        King of Kegstands
        • 14396
        Well it's not going to rev that high if it's a little out of adjustment. Just look at the throttle body and you can tell if it's closed. If it is, I'd suspect TPS and ECU first.
        • willworkfore30s
          • Aug 2011
          • 1090
          Common sense tells me that when im off the pedal the cable should be just a little slack as in not affecting the throttle and when I am at full pedal the throttle should be as open as it will go. I believe it is that way but I will check it again.
          • willworkfore30s
            • Aug 2011
            • 1090
            For anyone with similar issues, check out this write.
            http://pelicanparts.com/bmw/techarti...leshooting.htm
            When I get some time to work on the car again I am gonna use this to see if I can track down the issue.
            In the mean time, and wisdom and advice is more than welcome
            • io_RobbieRodgers
              • Nov 2011
              • 57
              Also, there's a weird screw that sets the minimum valve opening on the outside of the throttle body. Mine came loose when I was driving one day and all of a sudden my car was idling at 3k. Made it really hard to shift.
              Reformed E34 addict. 1993 525i/5 - 1995 525i/5 - 1991 318i/C
              • Marauder42
                • Jul 2011
                • 170
                Any ideas on whats causing that? ...
                because, racecar! Lol
                • mr ilia
                  • May 2011
                  • 582
                  Check throttle cable @ TB. There is a little plastic scre to adjust it, it might be off its peg. Also, you can try playing with it to see if it helps your idle. If you're able to ajust RPS scewing with this scew, then this is your curplit.
