Temp gauge and gas gauge stoped working
    Last night after work I got in my car and turned the battery on and my battery light and abs light were the only lights on. When I started my car I noticed my gas gauge and temperature gauge don't work while driving I noticed my mpg gauge was all over the place. Before all this my brake linning light was on before this problem now it's not on. Could this be a bad connection or a bad fuse? Any ideas?
    Any help?
      Heater doesn't blow at me but does defrost the windshield
        Might be time for a new cluster. Their fairly cheap and pretty simple to install
        r3v does not fuck around. First you get banned, then they shoot you
          SI batteries need replacing, while you're at it, check the ground nuts at the back, two m8 nuts at the back.
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
            you got more problems than just a new si board if your blower is doing that might need a new heater box if it only blows thru the top
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
              It doesn't defrost any more. When I start my car the brake lining light flickers and when the cars on the battery light and the anti lock light stay on untill I rev. Should I replace the batteries or the cluster? Could the blower motor failling cause the cluster to durp? I'm clusterfucked....:/ lol
                I found my problem!! I had a blown fuse. Thanks for the help tho
                  always start simple
