Before I swap in....
  • craiggroves91
    • Oct 2009
    • 3024
    A good running m42, can this baby be fixed?
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • io_RobbieRodgers
    • Nov 2011
    • 57
    Anything can be fixed, unless your block has a hole in it, or cracked in half.
    I can't hear what you're saying in the video too well, I'm in a loud place, could you give me a summary of the problem?
    Reformed E34 addict. 1993 525i/5 - 1995 525i/5 - 1991 318i/C
    • craiggroves91
      • Oct 2009
      • 3024
      Runs very choppy, like its misfiring. Dies at times.
      Feels like it may have a little loss of power.
      I don't really want to throw much money at it if any at all.
      I have a good running m42 I was just trying to see if this m42 is salvageable.
      1989 BMW 325i SOLD
      • xwill112x
        • Jan 2009
        • 4236
        Compression Test. Then post back.
        • io_RobbieRodgers
          • Nov 2011
          • 57
          The biggest concern I would have is that you could swap in a new motor, and you'd still have the same problem due to the fact that it was the peripherals. When you unplug the ICV, does it run fine? Does it run well driving around like that?
          If it's a problem internally in the motor, my first instinct would be dirty cylinders, holes in the headgasket or worn out piston rings.
          The first thing you should do, though you've probably already done this, is check all the vacuum lines around the intake. If you've got some spare time, take off the manifold and see how crappy it looks around the injectors and towards the intake valves.
          It could also be an ignition wire problem, but if your car runs better without the ICV plugged in, I'd look around more in that area.
          • io_RobbieRodgers
            • Nov 2011
            • 57
            +1 on the compression check, that'd alert you to piston ring failure or worn valve seals.
            • craiggroves91
              • Oct 2009
              • 3024
              Hopefully doing one tomorrow!
              Well I think it runs better with the ICV unplugged because it raises the idle. When it idles low it wants to die. ICV connected or not it still runs wrong with a misfire type sound, but it feels decent through the rev range.
              I have checked out the vac lines, but ill look some more!
              tomorrow I should be doing one!
              1989 BMW 325i SOLD
              • 3bvert
                • 1032
                your car will run wiht the throttle position control valve unpluged.
                It will run like crap if you have a bad one
                you can test it by unplugging and starting, run good, better, then replace
                still got the throttle warmer crap, get rid of it, prob can be there and you can not see the hoses
                without seeing a comp test, I too suspect externals
                • craiggroves91
                  • Oct 2009
                  • 3024
                  compression is good
                  1-4
                  215, 210, 215, 210
                  1989 BMW 325i SOLD
