do i need the fan clutch tool?
  • mr.vang
    • 4371
    i'm going to replace my radiator tomorrow, do i need a fan clutch tool or do i even need to remove the fan clutch?
  • Massimo
    • Jan 2008
    • 3207
    No and No.
    The fan clutch just requires a spanner and a BFH and a lot of swearing, if it has never been removed before.
    • george graves
      • 19997
      Are the fan clutches different on m42's? Someone told be that you can by a long spanner (32mm IIRC???) at bicycle shops - they use it for something - I forget what for. Just FYI.
      Originally posted by Matt-B
      • Massimo
        • Jan 2008
        • 3207
        IDK I just us an adjustable spanner and whack it with a big fucken hammer works every time.
        • mr.vang
          • 4371
          Originally posted by Massimo
          No and No.
          it looks like i can slide the fan shroud out without removing the fan. the bottom portion of the shroud has a cut that look to be design to fit the fan when pulling the shroud upward.
          • Massimo
            • Jan 2008
            • 3207
            Correct getting it back in is a bit of a pain though.
            • mr.vang
              • 4371
              thanks, well see how it goes tomorrow.
              • Ian Bowers
                • Apr 2008
                • 1120
                You can slide the shroud without pulling the fan clutch, and put it back in. Not very hard at all.
                Also: M42/M20 both use the same wrench for their fans, I think I picked up a 1.25" wrench from Ace Hardware for $13, was super thin and works great.
                • Ryann
                  • 3350
                  I concur. No need to remove the fan/clutch assy. for radiator replacement.
                  • vpilarrt
                    • Jun 2006
                    • 2096
                    IIRC the fan nut tool is the same as an M20 (and most other models) but the water pump pulley holding tool is different.
                    • MikeDE
                      • 1873
                      ^32mm/1.25" from Ace, cheap and effective. BTW, just incase you didn't know, the fan clutch is reverse thread.
                      -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                      • RoadWarrior
                        • Jan 2011
                        • 77
                        Visegrips.. Take out that mechanical fan and throw a 20 dollar slim fan on there.
                        • immajackuup
                          • Dec 2010
                          • 1132
                          i raise you with a plug and play e36 fan for 100 bucks new.
                          • bmwm42
                            • 6300
                            how much for the catch can
                            Originally posted by bmwm42
                            PNW vulture pm me for parts
                            Strategic nw e30 command
