Clutch has no resistance/pressure
  • Learning
    • Feb 2011
    • 70
    Hi folks,
    I was driving and suddenly the clutch of my '91 318i had no pressure/resistance and I couldn't shift the gear. What's the problem and how to fix it?
    Thank you.
  • bmwguy325is
    • May 2011
    • 1263
    Did the pedal stick to the floor? Now the clutch will not disengage? Most likley the clutch master. A few more details would be nice.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • Learning
      • Feb 2011
      • 70
      No, the pedal stays at normal position, however, when I press on it, it feels extremely loose like nothing is there and when the pedal touches the floor, it makes sound like it's hitting a metal. I checked the brake oil reservoir which is connected to the clutch and it was fine. Also, the carpet near the clutch pedal is not wet.
      • bmwguy325is
        • May 2011
        • 1263
        Than the cylinder on the trans itself has gone bad and or the pressure plate is busted.
