[Also posted over at m42club -- hope that's OK]
This past weekend I completed the "Mess under the intake" delete, but have ended up with worse idle and a "Check Engine" warning. Car is a 91 318i convertible with 142K miles. Very well maintained and ran perfectly, until the port on the top of the plastic coolant pipe snapped off. In an effort to make things simpler, I followed the many threads available here and on several other forums. I capped off the top port on a new coolant pipe, and the water outlet from the head. Deleted vacuum and water hoses under intake, leaving a vacuum line from the valve cover to the throttle body, and another from the ICV to the air inlet boot. The pictures in the following thread are exactly what I see (minus the clean engine):
http://www.m42club.com/forums/showthread.php?t=3621
I did leave the throttle body heater plate in place, simply because I did not have any cutting wheels for my dremel to shorten the studs: there is no water lines running to the heater plate. The plates ports are not capped off, since it appeared to be a closed system into itself.
During the tear-down I cleaned out with intake manifolds and sprayed down the fuel injectors; I did not remove the injectors. I used two new gaskets for lower then upper manifolds, along with a new throttle body gasket.
The vacuum hoses from valve cover and ICV do not appear to be collapsing and I've found no coolant leaks.
The problems are rough coughing idle, an intermittent "Check Engine" light, and a high pitched whining sound from the top of the engine. The sound isn't quite a whistle, but is related to RPMs and very noticeable from inside the car. The idle smooths when revved high, and on a quick trip around the neighborhood the car ran decent. Pulling back into the driveway was loud and painful.
My concerns are that I:
Any suggestions on correcting the issues? Anything jump out that I may have forgotten? Thanks for the help!
John
- mucked up a fuel injector by just spraying it off externally
- seated something incorrectly and created a leak somewhere on one of the manifolds
- angered the Gods by working on the car on SuperBowl Sunday
John
