Oil Leak
  • Threehz
    • 1480
    Oil Leak
    Oil leak is coming from somewhere lower on the engine and in the rear like where it would connect to the transmission.
    What seals are there in the back of the engine that could leak oil, rear main seal?
    It has to be something in that area or the back of the upper oil pan.
    Different strokes for different folks.
  • jrobie79
    • Mar 2006
    • 2524
    rear main seal...tranny has to come off, while you do that you might as well do the upper pan gasket too
    1991 318i ---- 308K - retired
    • immajackuup
      • Dec 2010
      • 1132
      the reason why I'm starting to hate m42 motor.
      • barry
        • 1642
        Also could be your slave cylinder taking a dump..
        • ///digitalme
          • Dec 2009
          • 2088
          also make sure your front crank seal is not leaking, mine was leaking and seemed like it was the pan gasket...then it was leaking again and figured out it was the crank seal, and filter housing leaking
          • Threehz
            • 1480
            The PO replaced the upper and lower pan gaskets pretty recently before I bought the car and I want to say it's not the pan, but you never know.
            When you say tranny has to come off, you just mean detaching it from the engine right?
            Or do you mean you have to take it OFF for access to the seal?
            Well if I ever have a half hour of free time I'll get her on jacks and get a good look up in there.
            • 3bvert
              • 1032
              yes tranny out. lioke not in car anymore out, not just loose
              not that big of a deal, there is worse things out there
              • Ryann
                • 3350
                If it's engine oil it could be the cam cover, upper pan gasket, rear seal housing gasket, or rear seal.
