Relocating ICV?
  • bstarr3
    • 170
    Relocating ICV?
    Doing the mess under intake, and it seems that with non-stock hose, it would be easier for the ICV to be somewhere other than bolted to the firewall side of the intake manifold. The tubing I'm using (5/8 reinforced heater hose, the stiff kind) makes it hard to fit in the stock position because it's not preformed in those nice little bends.
    I know some people have relocated their ICV when doing the mess, but is there a good place to secure it? I don't want it just floating around in the engine bay. Any suggestions, or should I just suck it up and put it where it belongs?
  • KenC
    King of Kegstands
    • 14396
    I used brass 90deg fittings and hose clamps.
    Originally posted by Gruelius
    • bstarr3
      • 170
      and bracketed it back under the intake manifold?
      • KenC
        King of Kegstands
        • 14396
        Well it's more behind the intake manifold, but yes.
        Look through my user gallery and there's probably a photo.
        • bstarr3
          • 170
          Thanks. This is exactly what I was looking for. I did almost exactly the same thing, with stock tubing from manifold to ICV and heater hose with 90 degrees from ICV to intake boot. When I tried to bracket it up it wouldn't align properly with everything plugged in, though. Guess I've just got to keep messing with it.
          EDIT: by the way, your engine bay looks the way I dream mine one day will. Great work!
          • immajackuup
            • Dec 2010
            • 1132
            I have the same setup^^
            don't use brass,buy this 90 deg plastic.
            Connector 1 11151277301 $1.60
            use a regular 5/8 hose.
