So I'm bleeding my radiator after doing mess under intake. Following this method :http://www.esatclear.ie/~bpurcell/31...nce.html#bleed
I filled both the expansion tank and the top radiator hose to jump start things. Hot air coming out of the heater, check. Top and bottom radiator hoses hot, check. Nothing really bleeds out of the screw until I rev it. But then I get lots of bubbly coolant. I kept it revved to about 3500 and was getting a steady stream of frothy bubbly coolant, then just steam. Now, I don't remember steam coming out of the bleeder screw as part of the procedure, and the temp gauge is close to red, so I turned it off. I turned it back on to take a quick video of my valvetrain tick (see next thread) and it started leaking steam straight away. Is this just lots of air getting out, or is something wrong here?
At any rate, I'm running out to let it cool off and do some errands, so I'll try again when I get back. BTW, front end is up on jack stands.
