So for the past few days I've been trying to get my build to run with no luck
I have 150psi compression across all four cylinders, spark, and fuel. The car barely starts, sputters for a few seconds at most then stalls out. If I hold the throttle open and crank her over she gets a little more rpm then lets out a few backfires thru the intake (dBilas ITBs) before completely stalling. I've checked the timing and everything looks good there, but she just doesn't seem to be firing properly. Swing away with ideas, I'm all but fed up at this point.
