Diesel chugging
    Diesel chugging
    This is twice now that this has happened. Car will be cranked and shut off at some point after driving. Upon recranking, it will have a very low sporadic idle and then shut off. This last time the car actually did this while driving and then again after I parked it. If I let it sit and cool down some (15/20 mins) I can crank and drive like normal. I already checked the hot start issue wire and it is unplugged. No known vacuum leaks, new plugs/wires, good afm. Any ideas?
    I've been having hot start issues too...
    Does it only have issues at idle and start?
    Different strokes for different folks.
      Well its happened after driving just on startup. The idle is so rough when its doing it that giving it some gas has never helped. Only fix so far is to let it cool down so far.
