m42 quick question
  • dougie30
    • Apr 2012
    • 1708
    m42 quick question
    Can the m42 engine just bolt into my e30 that has a 325e?
    i was wondering because i either want to get an i motor or a m42.
    i would love the lighter m42 but i dont know about the lack of hp? and the m42 does also get better gas than the 325i, so as you can see im not exactly sure.
    which would you guys recommend? i want to see some facts :D
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • Threehz
    • 1480
    I believe the 325e & are both heavier than the 318i or is and not just because of engine. So putting an M42 into a 325e body would probably not give you a lot of power.
    Different strokes for different folks.
    • dougie30
      • Apr 2012
      • 1708
      ohhh i meant just the engine weight, not the whole car lol
      • AndrewBird
        The Mad Scientist
        • 11898
        Yes, it will bolt in. The front crossmember is the same in all e30's. Depending on what transmission you use, you might need a different driveshaft.
        • Ryann
          • 3350
          I'd recommend selling your eta and picking up a good used m42 car if you want to go 16v.
          • dougie30
            • Apr 2012
            • 1708
            yea i know i would have to get a 240 trans but what type of drive shaft would i need? and why?
            • mr ilia
              • May 2011
              • 582
              You will likely have to swap diff for something w/shorter ratio.
              So, I would think you will need m42, g240 and driveshaft out of m42 car.
              I love m42 for its "top end" character. It really gets fun from 4000 rpm +.
              • xwill112x
                • Jan 2009
                • 4236
                Just do a m50. Or back stock E engine.
                • VANOS714
                  • Nov 2011
                  • 1195
                  Dont do it, just sell it and get yourself a 318is.
                  • gearheadE30
                    • Jun 2007
                    • 3734
                    If you're going to go to all the trouble to swap an engine, may as well go for an M50+. It's not that much more work, and the results are much more satisfying.
                    Project M42 Turbo
                    • TimKninja
                      • 2131
                      The M42 is alot more fun then the B27 IMO. Ive had both. Plus im managing tp get like 27 MPG out of the M42. I never got that with the ETA.
                      Ive also had an m50 e30. That was after i ripped the stupid m20b27 out .
                      Lets just say I havnt ripped the m42 out of my car quite yet.
                      1985 325e M50TU(Sold)
                      1991 318is Slicktop (Sold)
                      1990 325is Brilliantrot S50/5 Lug Swapped.
                      1992 525i Manual shitbox Winter Beater
