trying to get my crap together for this. Anybody know if this fan will fit to replace the stock A/C fan? I'll be keeping my A/C.
Which brings up another question.....
When I install turbo:
Do I have to get rid of stock mechanical fan and move over to electric? I see photos where it didn't seem to fit that well with mechanical fan, if at all.
If I install the big volvo puller fan to come on at 80 or 82 or whatever the lower temp is, using the stock power to trigger the larger volvo relays with separate power since it draws so much, would I still need the spal pusher to come on with A/C switch?
Is installing the volvo fan, in essence, utilizing the same circuit that previously drove the A/C fan? As there was a mechanical fan from the factory, I assume that is the case. If I use both fans, would I just wire it as such that the A/C switch activates the spal pusher?
Thanks,
Tom
Thanks,
Tom
