Originally posted by Wizard
Just want to run this by you guys to see what you think.
I plan to splice the yellow wires into the rad temp sensor, hi to hi, low to low, then simply run the last red wire to the battery with a inline fuse. Sound good? Should be able to keep the aux fan independent correct? If it overloads the alt, I'll simply disable the aux fan.
