Finally opened up the timing case on the M42 that's going into my early 318.
Already knew I need new main sprockets (which I have acquired already), but hopefully you guys can take a look at a few things and let me know how they look and/or how to check their condition
First, the lower sprockets. One looks very good and the other has very sharp points on it. I assume they both should look like the upper one, correct?
Here's the full case open. I do have one tensioner that has low wear, but is there any way to tell the wear on the tensioner/chain guides from here, or will I only know once I take them off? Also note that there are no pieces of the guides/tensioner in the case, so they haven't broken or anything.
This is the profile gasket? It looks to be sticking out a bit.
but on the inside all the way around it is pretty even. Looks to have a seal. Thoughts?
anyhow, thanks in advance for the inputs.
