M42 ticking when driven angressive
  • willy-guldager
    • Dec 2012
    • 23
    Hey, My 318is from 89 is causing me a little frustration. When i drive it normally on the road it doesnt say anything. it is just normal and good but when i take it down a twisty road and push it to the limit with drifts and stuff the ticking starts. What is this making this to happen? Cam shafts getting hot? How can I solve this problem??
    Best regards William
  • butters
    • 1206
    Hydraulic valve lifters are oil-pressure driven. When you push the car, something is causing a drop in oil pressure or perhaps air getting into the pump, something along those lines. Examine all points of possible oil pressure loss, test system pressure with a mechanical gauge, and if you don't find anything unusual you may have lifters going bad.
    • jntar
      • 459
      Oil starvation from aggressive driving isn't uncommon. The next time you want to go drive spirited try adding an extra 1/2 quart of oil.
      M42 turbo build.
      http://www.r3vlimited.com/board/showthread.php?t=301330
      • willy-guldager
        • Dec 2012
        • 23
        Okay thank you very much guys. I better check the oil level then :)
        • Vivek
          attention whore/retard/bitch
          • 6167
          Originally posted by willy-guldager
          318is from 89
          Wait what?
          What oil weight are you using? You shouldn't be under 20-50 in the warm and not much lower than that if it's cold. That could also cause ticking.
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • bmwm42
            • 6300
            Originally posted by Vivek
            Wait what?
            bullshit oil weight has nothing to do with ticking im running 5-30 no tick what so ever he either has clogged shitty lifters, a pump with worn down teeth or ethier of the above
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
            • AndrewBird
              The Mad Scientist
              • 11898
              If his pump is worn, thicker oil will help up the oil pressure. Thin oil can create low pressure.
